11-21-2009, 04:01 PM
Re: large battery bank
Sprinter charging system will not handle that battery setup. You would have to use a charge controller when charging from the alternator, and charge from AC whenever possible.
That's a lot of weight to add to a Sprinter. Unless it's a DRW version.
But, mounting them underbody is ideal to keep cG low.
11-21-2009, 05:58 PM
Six 8D batteries will be very expensive when it comes time to replace them. Also keep in mind that with multiple batteries, if one needs to be replaced, they all should be replaced at the same time.
11-21-2009, 06:57 PM
1)
what are the specs on your power requirement for daily use
2)
what is the weight capacity of your sprinter
3)
how much will the build out weight
4)
engine size
5)
you need the proper after market alternator
6)
you can use a big ass battery switch so you are NOT trying
to charge them all the time
7)
you for sure need a Sure power bi directional (or equivilant) battery isolator
8)
what is your solar set up
9)
what kind of fridge
(my Truck fridge 4.2 cf will run 2 full days on one 200 amp hour 4d)
10)
runing the Air Conditioner 6-8 hours???
what are the specs on the AC?
Have YOU done the calculations on running a AC 6-8 hours off inverter?
(dont rely on anything someone just tells you)
11)
8 batteries X $500 = $4,000 + shipping + install = $5,000 replacement
better make sure you do the math correct as you can fry the batteries pretty easy
(common knowledge is ya gotta replace all or none at the same time)
11-21-2009, 11:17 PM
Six 8d batteries would have 225ah X 6 = 1350ah. But you can only use about 50% of this value over an extended period of time w/o shortening the life of the batteries.
So 225ah X 6 X 0.5 = 675ah. At 12 volts that is 675 X 12 = 8100 watts of power. Assuming you loss 20% through the inverter going from DC to AC that leaves you 8100 X .8 = 6480 watts of usable power. Convert that to BTU's and you get 22,111 BTU's of cooling power IF the AC unit is 100% efficient.
For 8 hours of operation that gives you 22,111 X 1/8 = 810 BTU/HR of cooling. That is not much cooling. Seems like a very small AC unit.
Len & Joanne
The Green TARDIS
11-22-2009, 08:03 AM
I bow to LenS calculations
I use a Colman Polar cub
8 amps
900 - 1,100 watts for cooling
If LenS calculations are correct
8,100 watts divided by 1,100 watts would give you 7 hours with a Polar cub
but thats a SWAG and does not include lights, fridge etc
Methinks it would be very easy to fry batteries even with the Polar Cub which is
the smallest roof air i could find
Lets see what stats the OP comes up with
(LenS, are MY calcs correct?)
11-22-2009, 10:42 AM
1st, I want to thank all of you who replied to my cry for help, as I know nothing about the real-time electrical needs of my conversion, SO PLEASE KEEP THE INFO COMING!!!!!!!
I am retired from the K-9 unit. As a hobby, I need to travel with up to 6 dogs, to dog shows and dog sport trials. I also do search and rescue, drug and accelerant detection (arson). Sometimes I am parked in a building or arena (no electric to hook up to) and cannot run the gen
The sprinter is a 3500, up to 11,000 lbs, so added weight of the batteries is no problem
The alt is a 220
I took this from their site http://www.sportsmobile.com/2_sr_heatingcooling.html With the Danhard A/C, a 2000 watt inverter and two 100 amp auxiliary batteries (one is standard equipment), you can normally run the A/C for one hour with van's engine OFF, provided the auxiliary battery system is fully charged.,
I assumed I could just X's that by 6
the fridge... Amperage draw 12V 3.2A, 110V .04A http://www.thetford.com/Home/Products/N ... fault.aspx
I will also have 2 solar panels.... Kyocera Specifications: Max power output 135 watts.
Max voltage 17.5 volts Max current 7.4 amps/hr
PLEASE KEEP THE INFO COMING !!!!!!!
11-22-2009, 11:37 AM
Wow, that's a tough set of requirements to solve.
No matter your solution, make sure you have the right fundementals to minimize the need for A/C in the first place. My recommendations:
1) Choose a light paint color for the Sprinter
2) Have all windows tinted with heat reflecting window film. Not all window film is specifically designed to reflect heat.
3) Search through this forum for discussion on improving the van-body insulation. Not sure if there are any Sprinter-specific discussions, but I see not reason why the same applications wouldn't work for a Sprinter.
4) Though it won't work in places where you can't run the engine, but there's a Chilly Dog accessory that will turn on the engine and run the A/C (or heat) when the thermostat hits a certain temperature.
Good luck in your quest, and let us know what you decide. I know SMBw has a lot of experience in designing their conversions with dogs in mind (Dubai or UAE rescue vehicles), but I doubt they were designed with non-running engine or generator.
11-22-2009, 01:14 PM
Mrs. Wilson and i also have a Dog
so we built our rig with the ability to
duct tape him up and leave him in the rig
with the Coleman Polar cub running
.... just kidding about the duct tape
alternator
after market available for 300 amps
insulation
do your homework
consider dynamat also
YOU need to see insulated truck BEFORE panels go up
factory has been known to leave holes (search posts)
Solar panels
Up Size from 130 to 180
may require a custom rack from aluminess but WELL worth it (see my gallery)
make sure you have MMPT (some deal that maximizes charging) with the solar controler
I use a Blue Sky controler
Window tint
agree with Max reflective
Fridge
what model you getting?
Generator
which brand and model?
the link sends me to a huge double door deal
A/C unit
Why Danford vs. Roof top?
Why not have both?
(Polar cub is only $600)
JMHO
11-22-2009, 01:54 PM
#20
alternator
insulation
do your homework
Solar panels
Window tint
Fridge
Generator
A/C unit
Why not have both?
JMHO
link to the fridge is correct (huge double door deal) I feed the dogs raw, so I need plenty of fridge space
the Generator http://www.powertech-gen.com/product_in ... ucts_id=27
AC .... There will be 2, 13,500 btu each. One is engine driven, the other is 110
