Old 04-21-2017, 05:05 PM   #1
MC4 fuse holder
Installing 2 Renogy 100w panels on the van. Roof entry will be with a Go Power cable entry plate.
Is anyone using the Renogy MC4 fuse holder with this entry plate. Do they just snap together or do you use a small jumper wire?
hogasm is offline   Reply With Quote
Old 04-23-2017, 08:51 AM   #2
My expectation is they would just go in between your existing MC4 connection, it would make for a clean installation.
2004 E350 EB V10 E/PH 2WD
Old 04-23-2017, 04:40 PM   #3
Bbasso's Avatar
My mc4 cables are 10ga so I bought 10ga fuse holders then I soldered them/shrink tubed them never had an issue.
Rob.
Current:
And had three other E350s...
Old 04-23-2017, 06:58 PM   #4
Bbasso did you install this before/after the controller or both before and after?
Old 04-23-2017, 07:16 PM   #5
Bbasso's Avatar
Huh... I forgot!
Most likely before the SCC and from the SCC to the house batteries.
Since I've seen 15 amps coming from my 2 100wt panels I used a 20 amp fuse...
Rob.
Current:
Queen bee
Deaner
"Campy"
campy
