Old 06-07-2013, 07:20 PM   #1
Morningstar prostar 30 load issues
I had the wiring and prostar-30 all rigged up and working perfectly for a year, today I moved the batteries outside to a new location next to the frame, all went well...at first. I hooked up the same wiring scheme as before. Now the Prostar is not reading loads. My big concern is that I used to be able to "scroll" through the battery volts/solar amps/load amps with the push of the only button on the thing, now whenever I hit it, it jumps to Load and turns it off. Upon a restart I get the code E07, which is a Load issue. I read the instructions Morningstar has online and followed them exactly, still no luck and when I turn the van on, the volts shown in the little display (on the prostar) used to jump (instantly) to 14.1 and now they creep up and eventually reach 14.1. . Any help would be much appreciated I am heading out of town tomorrow and need it working well (first trip with new baby!!!)
Thanks for any and all suggestions in advance.
C.
c7train is offline   Reply With Quote
Old 06-07-2013, 11:31 PM   #2
Re: Morningstar prostar 30 load issues
Some use fused shunts for metering. Not sure about your setup. I have had corrosion issues cause problems with volt/amp meters. Just a stab in the dark.
