Yes, just to be clear, I wasn’t intending to recommend the flexible panels from Renogy. Here’s the compact design I was thinking of, seems to be a bit longer and a bit narrower
Renogy 100 Watt 12 Volt Monocrystalline Solar Panel (Compact Design)
https://www.amazon.com/dp/B07GF5JY35..._NbEYCb1DDHB89
These are the panels I got, the high efficiency version, a bit shorter.
Renogy 100 Watt 12 Volt Eclipse Monocrystalline Solar Panel High Efficiency Module Off Grid PV Power for Battery Charging, Boat, Caravan, RV and Any Other Off Grid Applications
https://www.amazon.com/dp/B01B3TEM1E..._geEYCbAKEN5HZ
With any panel, you can run aluminum angle the span between and into the tracks and attach the panel to that, just maybe get the 1/4” stuff for rigidity. That way, you can run any sized panel you want.
