Old 01-21-2011, 03:31 PM   #1
winvest's Avatar
New Starter batteries installed at Walmart
I just had my starter batteries replaced at walmart. $197.00 for both installed. 3 year warranty. I wanted to go with the Odysees, but I started thinking about it, and decided that I would probably be on the road when or if I had battery problems, and when aren't you near a Walmart? For the price of the Odysees I can replace my Walmart batteries 3 times, that's 9 years worth if they only last as long as the warranty period.
'07 E350 4x4, voyager top, custom interior, prorock 60, arb front & back, aluminess front & back, hella lights, extreme air, braun wheelchair lift.
"Two roads diverged in a wood, and I took the one less traveled by. And that has made all the difference." - Robert Frost
winvest is offline   Reply With Quote
Old 01-21-2011, 05:20 PM   #2
Zeta's Avatar
Re: New Starter batteries installed at Walmart
Bought two of the super duper Die Hard Platinums 65 series (930 cca's!) for my '06 PSD RB50. No el fitto. The battery cables need to be where the molded in handle on top of the battery is. Ended up with a couple Motorcrafts. Only a lousy 850 cca.
Woe is me
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 01-21-2011, 06:32 PM   #3
More CCA's isn't always better. To get more amps, they use more, thinner plates. Usually that will mean less robust and shorter life.
I replaced mine with the same old 750 CCA battery as originally built.
Old 01-21-2011, 06:36 PM   #4
Zeta's Avatar
Interesting. They were super heavy I know. They also had a four year replacement and 100 month pro-rated warranty. What else for $190 a pop!
Z
'06 RB50 SMB Diesel
Betsy
darryldickie
VanBo
Mike Ponce
