Old 08-14-2012, 12:18 AM   #1
DosMars's Avatar
No power to outlets?
Our house outlets are not putting out any juice. Does anyone in the Long Beach, Ca. area have a recommendation for a place to take the SMB for a diagnosis/repair?
Test test test, this is where the signature goes
DosMars is offline   Reply With Quote
Old 08-14-2012, 12:45 AM   #2
BajaSportsmobile's Avatar
Re: No power to outlets?
First, make sure the circut breaker is not tripped and is on and then sure the GFCI is not tripped - in that order. There is not much that can go wrong.
AgileOffRoad.com
Old 08-14-2012, 06:04 AM   #3
danamrak's Avatar
Had this happen to us this weekend.....checked the fuses...but it was the GFI thingy that was the problem. Flipped the switch or reset it or whatever and bingo we had power.
Dick and Anne
DABEE a 2006 Ford EB250 with penthouse top.
Life Is Good.
danamrak is offline   Reply With Quote
Old 08-16-2012, 06:09 AM   #4
DosMars's Avatar
Thanks for the trouble shooting, I should have mentioned that the gfi and breaker have been ruled out. Is there anything other than the inverter I should check?
Old 08-16-2012, 09:55 AM   #5
If you have the tripp-lite inverter there are some resetable breakers, that will shut down in there was a overload.
from manual.
Resetting Your Inverter/Charger to Restore AC Power
Your Inverter/Charger may cease supplying AC power or DC charging power in order to protect itself from overload or to protect your
electrical system. To restore normal functioning:
Overload Reset: Switch operating mode switch to “DC OFF” and remove some of the connected electrical load (ie: turn off some of the
AC devices drawing power which may have caused the overload of the unit). Wait one minute, then switch operating mode switch back to
either “AUTO/REMOTE” or “CHARGE ONLY.”
Old 08-16-2012, 11:04 AM   #6
My Xantrex prosine is similar in operation. The main switch on the inverter itself may have to be reset.
Slightly off topic but another problem I've incountered is the RS-232 port/plug that goes from the inverter to the control panel. At times it might be necessary to plug and un-plug from both the remote and/or the inverter. Inspection of the wire harness is also something that might need to be done if the inverter fails for some reason.
Old 08-16-2012, 11:43 AM   #7
twogone's Avatar
Never underestimate the power of rodents
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 08-16-2012, 11:51 AM   #8
Or fat guys like me sitting on seats that pinch the wire
