Old 05-29-2016, 12:43 AM   #21
The two separators mentioned the surepower 1315 and bluesea ACR both commonly used by sportsmobile are Bidirectional, and will connect when either side is above the set point, for better or worse.
Thanks Greg, I didn't know that. I have a simple relay that closes when it senses the key is in the run position. I can see where a bidirectional seperator could be an advantage, like when the van sits for long periods with an alarm or other load on the start battery that would otherwise go dead.
Old 05-29-2016, 06:59 AM   #22
One downside of the Surepower relay type bidirectional units is that in very low sunlight conditions, a good portion of the solar power is burned up just keeping the relay energized......ie conditions where there is sunlight to get the voltage high, but not really making much current.
Old 06-26-2016, 05:37 PM   #23
alta825's Avatar
Alright. Finally had some time to drop the house battery and poke around. Battery terminals were a little corroded and there was evidence the lugs from the cables weren't in full contact. Cleaned everything up, filed everything flat and reinstalled. Also rewired the portable solar leads that I had originally installed directly to the battery to the internal 'junction' under the sofa and rerouted the hookup into the Propane compartment. So far the voltmeter only drops a 1/10 or 2 when fridge kicks on. No weird clicking either... Fingers crossed, need it to be dialed for our Targhee trip next wkd for the 4th....
Sent from my SAMSUNG-SM-G890A using Tapatalk
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
