01-29-2013, 01:20 PM
only 1 batterie for 7.3 Diesel ?
Hi, did anyone of the 7.3 Diesel drivers ever try to go only with one batterie? Also in wintertime?
Mine start without problems ( at unter 32F ) with one good batterie but i am not shure what will happen if temperature is lower or the batterie gets older. I plan to take the 2nd batterie for housing.
Thanks for answers
www.Dieda-unterwegs.net
01-29-2013, 01:33 PM
Re: only 1 batterie for 7.3 Diesel ?
I seem to remember being told that the voltage needs to stay above a particular level or there can be problems with the engine computer system...at least with the 6.0PSD's. So twin batteries helps with drawdown during starting, especially in cold weather. Could be a wives tail.
I had my winch throw a code when it pulled the juice down far enough while using it at idle. Ford said not to do that and keep a high idle or winch w/o the engine running. Not too sure about that either...I always run the winch when the engine is idled up now.
01-29-2013, 02:02 PM
Low voltage can kill the FICM (Fuel Injection Control Module) on a 6.0L. I don't think it is a concern with the 7.3L.
AgileOffRoad.com
01-29-2013, 03:36 PM
As long as you can plug in the block heater when its cold out, one battery will start it just fine. But I would recommend moving up to an AGM battery so give you a little better reserve capacity, in case you can't plug in for shorter stays.
01-31-2013, 03:13 AM
As i am new in the SMB world....where can i find this block heater? I have no idea!
I found it but did not help me because we have 220V here
01-31-2013, 07:52 AM
It's the 120v plug coming out of the front around the grill. Sometimes it's tucked around the front bumper somewhere.
01-31-2013, 11:01 AM
Do all PSD's have them? Mine(6.0) does but I thought some don't???
02-01-2013, 07:25 AM
I readed that all diesel are stock equiped but that it's an option for gaz vans. Is it right?
02-01-2013, 08:19 AM
Just replaced my starting batteries ('95 7.3) They are two different sizes on my van due to space constraints. The smaller one cost 50% more than the large one, and, had to be ordered.
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
02-01-2013, 08:23 PM
That is my understanding, at least for recent years. I'm not sure when it first became standard on the diesels.
