FYI, your lights run on 12v, while your frig will run on 12v or 110v (via shore power or inverter). Your frig is probably running on 110v. Likely if you unplug and turn off the inverter (or simply turn off the 110v breaker switch to it) the frig will not run. +1 on Greg’s thought that the main 12v breaker is tripped, if none of the other 12v accessories are working. Not sure why the power tip would work, though, unless somehow it’s on a separate circuit (my top is manual). Under your dinette should be a fuse box for the 12v system. It should have plug-in fuses and smaller gauge wire than the 110v breaker box. Try to find what looks like the main feed hot wire into this box, and there will likely be a small resettable circuit breaker inline there. My 12v breaker is a small black box with a VERY small reset button that’s easy to miss.
Home Depot/Lowe’s should have 12v switches. I think they may be in the hardware aisle in the small hardware pull-out boxes, but I may be wrong. Times like this I miss Radio Shack!
