Old 07-15-2014, 07:26 AM   #11
TexGX's Avatar
Re: Permanent Truck Battery Charger
Scalf77,
I store the Yeti in the garage so solar for charging will not work. I have added portable solar to the van. It has a controller on it so it is connect so I can monitor on the link. I agree that I need to go that route. I am currently using the van system to charge house batteries and a stand alone charger/maintainer. I will look at ordering a Blue Sea separator and start the process of figuring out what I need for install.
Thanks.
TexGX
TexGX
2003 7.3PSD RB50 Quigley (The Yeti)
viewtopic.php?f=10&t=13220
2006 Casita (Makes it a three bedroom 1 and 1/2 bath)
TexGX is offline   Reply With Quote
Old 07-15-2014, 11:44 PM   #12
KTMRIDER's Avatar
Originally Posted by Scalf77
First question I would ask, is what do you use today to charge your house batteries. You mentioned a inverter, is it inverter/charger or just a charger? Second do you have or do you think that Solar is in your future? If you already have a charger in your inverter then changing to the Blue Sea ACR may be the correct route, especially if you have or plan to have solar.
I would agree you probably don't want it running with inverter running while the alternator is charging. I think your idea of wiring it in before the inverter is the simplest and best solution.You could put a switch on that circuit, or even a relay driven off of van run circuit. I know there are a couple of members that have hardwired in a charger, hopefully they will chime in with their experience.
I believe if you are looking for a house battery charger the Xantrex truecharge2 unit can do multiple batteries.
http://www.sportsmobileforum.com/vie...lit=Truecharge
KTMRIDER is offline   Reply With Quote
