Old 01-25-2017, 05:56 PM   #1
Photos of House Battery Mount
I've done some searching but haven't had much luck with finding photos of under van (behind rear axle) house battery mount. My Lifeline 4d AGM battery arrived today and I'm wanting to fab up the tray/bracket.
Any help would be appreciated
Edit to add: I'm open for any ideas on design. I hated lowering the battery on my 04 SMB. What a PITA.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 01-25-2017, 06:13 PM   #2
On my build SMB just used angle iron and built a cage for each battery which runs between the frame. The batteries sit in marine battery boxes. I just wish I could make them lower easily. Right now I have to use a floor jack. I'll try to get a pic for ya.
Old 01-25-2017, 06:19 PM   #3
Here it is:
Old 01-25-2017, 06:43 PM   #4
B350's Avatar
I added a frame cross member to mount a hinged dual 4D batter tray behind the axle. Behind the battery tray is a water tank which utilizes another frame cross member. The stock one was cut out.
'99 E350 EB 7.3L, 2WD, WeldTec lift, CCV Mid Top
B350 is offline   Reply With Quote
Old 01-25-2017, 09:23 PM   #5
B350, I was hoping you'd chime in. That box is bomber! It's the best one I've seen.
Old 01-25-2017, 09:37 PM   #6
That's slick! It looks like it bolts up to the frame so its not adding any stress to the hinge while on the trail correct?
Old 01-26-2017, 06:38 AM   #7
Bbasso's Avatar
Since most of our batteries are usually in excess of 100 pounds wouldn't it be more efficient to place that weight in front of the rear axle instead of behind it?
Rob.
Current:
And had three other E350s...
Old 01-26-2017, 08:19 AM   #8
B350's Avatar
Correct daveb. It bolts up at the hinge side and opposite so the hinges do not carry any of the battery weight. Just unbolt the 5 mounting bolts and pivot the tray downwards. The water tank carrier with skid plate does the same thing.
Bbasso, I think if you're talking about 1 4D battery at about 125lbs the weight is negligible in comparison to water and fuel tanks behind the axle. My setup with 2 4D batteries and 30 gallons of water (completely full) will weigh in at about 500lbs. Granted that is a lot of weight but consider that a 55 gal aft axle fuel tank would weigh in at about 330 lbs with gas or 385 lbs for diesel. So, one battery will not be noticeable.
Old 01-26-2017, 09:19 AM   #9
Flux's Avatar
Not a pic, but a concept I am working on to mount my 4D battery.
On my EB, there is a cross member just behind the axle. The Top Flange with the return would hook over that and then I would use an additional cross member to support the other flange that could be removed to drop the battery straight down. I am planning a 3D printed cover for the blades that screws into the top plate flange. The top plate will secure the battery with 4 3/8" bolts. the bottom of the box will have a cutout and padding to keep the battery from sliding around.
Design is still a tad rough. 1/8" formed Mild steel with welded on end caps. Ran it through a stress simulator and it's fine for that weight and more. Just my idea.
<br>
Old 01-26-2017, 09:42 AM   #10
rallypanam's Avatar
My slightly modified SMB 4D passenger side frame mounted bracket.
