Re: Plugged into Shore Power for a wk but can't start???
ucsundog.,
So if the GFI was tripped, you would have had to reset it to read the power that you say was there in beginning post. You mentioned Tripplite so, I expect means you’re talking about one of their inverter/chargers. If so then the SMB GFI circuit would be after the inverter. When you say the circuit breaker was tripped, which circuit breaker are we talking about, the DC circuit breaker from battery to fuse distribution? Also if the radio switch was set to Van, than I would expect that it was just off, do to accessory power going away. Being set on house, could cause you some issues, but I do not see being on Van as a issue. The fridge on 5 would have drained the house battery, if the charger was not on pretty quickly. Even with that if the separator was working correctly I would have assumed you would have saved you’re van batteries.
If the batteries are really low the Tripplite will not even start to charge them. but you should get some blinking lights on the inverter/charger. A common failure mode of the separator is to stick in the on position, this of course could relate in a issue that would take down all the batteries. So I would check that out also. I am not sure what Peter is trying to tell you about charging from inside and then grounding, but yes if you get the house battery up a little then it should be able to charge, again you should have some indicators on your Tripplite.
Greg
