Old 05-20-2009, 09:00 PM   #21
Re: Pop Problem
Originally Posted by jage
After a day or so on shore power I'm going to test the top and see if there is still a mega drain with just one battery.
That should work OK. If you know anybody with a carbon pile tester you can check it faster but I would still try to find out why the top draw is so much (if it truely is) just to make sure. Do the amp check while putting up the top. You have the same lift as I do and its never over 4 amps. That's like a couple of lights!
Old 05-20-2009, 11:54 PM   #22
Greg In Austin's Avatar
Re: Pop Problem
I suspect the draw is not really that high, but it is the weakness of the battery that makes it seem to be high.....
I just replaced two batteries in my laptop... suddenly when I went off shorepower one battery would drop from 100% to 75% to 30% in no time flat.... but the aptop is not drawing any more.
New battery in place. Problem gone.
Greg in Austin
