Just curious, does the Zamp controller you have show voltage displayed on the controller? Amps?
I guess if all else fails, I'd pull the controller and make sure it's connected correctly. While its out you can check voltage and continuity on the circuit. I also would check if the remote outlet is being fused behind the plug as well as at the controller. I think the reason for isolating the portable panels via a switch is some don't pare well together with different types of panels.
