Old 04-02-2012, 04:58 PM   #11
Re: Portable winch wiring
It will sit in the back of a Chevy Tracker. Maybe I'll weld in a vertical tube to sit in it so I can lock it, although the 2ga cable is probably more valuable
Any ideas for a junction box for the plate? Maybe it would fit in a standard outdoor ac box.
Rob
Old 04-02-2012, 07:10 PM   #12
I get "project enclosure"s at radio shack. Not sure how big they carry.
http://www.radioshack.com/search/index. ... w=box&sr=1
Old 04-04-2012, 08:25 PM   #13
Originally Posted by Carl
Where will you mount the winch when not in use?
Where will you have it on/in the Sportsmobile while you are traveling, mounted in front receiver, mounted in rear receiver, in a floor mounted floor box, in an interior cabinet, in an Aluminess exterior box, etc.?
Old 04-05-2012, 10:08 AM   #14
As I said, it will be in the back of a Tracker. So not in or on the SMB. If I did need to carry it there, I'd just stick it in the first handy place.
