Trimetric Install Update
OK - so here's my update.
I emailed Bogart and they responded within 24 hours. They advised me that it would be fine to connect the shunt up to the starter battery as long as I had the 500A/50mV shunt installed (fortunately that's the one I ordered). - As a side note - when I crank the engine the Amps shoot up to the mid-50s for a couple seconds and then drop back down to a steady/stable value which the alternator is charging at.
I spent Saturday morning reading over the paperwork they sent with everything, and wiring up the monitor in a long-term, temporary install (or short-term, permanent if you prefer).
I disconnected the negative battery terminal from it's post and ran to/from the shunt mounted underneath the driver seat. The last step was putting the fuse in. Fortunately they gave me two, because I dropped the first one into the battery enclosure and it's now under the battery which I wasn't in the mood for removing! Anyway, the fuse went in and the lights turned on. It appears to be working perfectly.
I set P1 (MB 2500 Sprinter 4Cyl Diesel 95Ah AGM battery) to 14.4V (Full Charge Voltage), P2 to 2% (Full Charge Current) and P3 to 100Ah (Battery Capacity).
It's very cool to see the effects of different loads on the system (i.e. dome lights, radio, A/C, headlights, etc). In hindsight, I'm very glad I didn't leave my 12V cooler plugged in overnight.
I've attached a couple pictures to show the installation. Recall that this is not final. It's temporary until I have all my equipment and plans finalized.
The next step is the Inverter/Charger.... MMS1012 or the MS2012...??? I really want to go with the smaller one, but at 1000W it's only putting out 8 amps, so I feel like I'm slowly talking myself into the MS2012.
Thanks for everybody's input and help!
PS - the Common Ground on my diagram was the last thing I drew in, and I stopped showing groundings because it would have made the drawing more messy and not necessarily added value.
