Old 02-13-2018, 10:50 AM   #1
Rear door lock?
Have this plug at the rear door but nothing else is there to electronically lock the door. What else do I need? All other doors work by the switches.
hogasm is offline   Reply With Quote
Old 02-13-2018, 01:39 PM   #2
You'll need the servo itself which attaches to the door shell and in turn has a rod that fits the door latch.
Is there a switch in the lower left corner of the right-side door, the one with the license plate and handle?
Old 02-13-2018, 02:42 PM   #3
This is the only plug in the right rear door. There is no switch. I would think there would need to be a TEE wire harness to connect the switch-servo-and this connector
Old 02-13-2018, 04:53 PM   #4
If the switch isn't there that's not a problem unless you want one---it could be added at any time.
The servo simply connects to the plug you show. The door lock servos are designed to work whenever any connected switch is actuated; you can add or delete as many switches as you like just as long as an actuation switch exists somewhere in that circuit.
Adding a switch pretty much requires an EVTM or at least the schematic pages for the door locks. Vehicles with RKE work slightly different but only when the key fob is used, otherwise all switches operate all servos simultaneously.
ClifFord
EliMakes
The YURT
MKRyan
