Old 11-11-2018, 01:58 PM   #1
Remove Converter - Inverter Charger Install
Hello smb community. Newbie with electrics.
1) Looking to replace converter charger with Kisae 2000w inverter Charger
2) I just want the inverter to power smb outlets from house battery when no shore power is present to power a 600w microwave, a HP all in one touchscreen. Also want the inverter Charger to smartly charge house battery and pass through power when on shore power.
Please see pics of current setup and what Iím about to do and let me know your thoughts. Thanks and cheers.
Inverter user guide
https://pdf.donrowe.com/ic121040_ic1...ners_guide.pdf
Inverter spec sheet
https://pdf.donrowe.com/ic121040_ic1...spec_sheet.pdf
Old 11-11-2018, 03:47 PM   #2
Hereís my current setup
3092AD64-C82B-43FA-A273-DA17A3333E03.jpg   96A21C04-4F19-4CF2-9444-BDEC932B895F.jpg   A75A7BA9-1C6C-4D9E-9816-8DF44D2C39DC.jpg   28668BEA-F45A-4A9D-B2F1-E9EEB4DB9E05.jpg   082389F0-4DFC-49F0-AE33-4017E2D6B740.jpg
Old 11-11-2018, 04:14 PM   #3
Also can I run cable from the existing house battery terminal thatís in this pic to the 300a anl fuse to my inverter or should I run a separate cable from the house battery post?
