Old 01-24-2017, 04:34 PM   #1
replace toggle switch
Hi, we accidentally broke the toggle switch on our SM and it needs to be replaced. The switch is located below the seat so it is easy to kick it with the foot by accident.
the switch that is currently in there is this one here https://www.alibaba.com/product-deta...353789414.html
I am looking for a sturdier switch to replace it with. any ideas? thanks jens
jankee65 is offline   Reply With Quote
Old 01-25-2017, 05:33 PM   #2
Bbasso's Avatar
How about a flat style rocker switch? Worst case scenario is you kcock it about and turn something on/off.
Just make sure it's rated the same to handle the power.
Rob.
Current:
And had three other E350s...
Old 01-25-2017, 05:35 PM   #3
yes good idea. i have a hard time finding a flat rocker switch that can handle 50 amp 12 v dc, but will keep looking. thanks!
Old 01-25-2017, 05:41 PM   #4
Look at digikey and mouser.....that's a simple toggle. Does it has two, three or six connectors on the switch?
......or Carlingswitch if you want the basic SMB rocker style.
Old 01-25-2017, 05:45 PM   #5
two connectors
Old 01-25-2017, 05:46 PM   #6
Chances are very good that the switch controls a relay that handles any high current. Accessory switches, if properly installed, rarely directly handle the full current going to the device. Tracing wires isn't fun, but it needs to be done so you can be sure.
Old 01-25-2017, 05:52 PM   #7
50 amp? What does this run? Sometimes a high amp load may require the use of a remote high amp relay controlled through a low amp control circuit.
Old 01-25-2017, 09:55 PM   #8
Bbasso's Avatar
50 amp? Highly doubtful a switch has that much running through it... (as already mentioned)
Also as mentioned, trace the wires to find out more about the source of power.
Worst case scenario, use a relay.
Rob.
Current:
