Old 03-04-2018, 08:47 PM   #1
rltilley's Avatar
Replacement Alarm Remote
I had Sportsmobile install an alarm in my van and the remote is getting a bit unreliable. Sometimes the lock button won't work and other times the unlock button doesn't want to work. This is not good when out on the road. The second remote is also unreliable so I'd like to get replacement remotes that I can program using the exiting units I have. Any recommendations on units that will work? My exiting remote is below. Amazon carries units that look similar but I have no idea if they would work on the system Sportsmobile set me up with.
One possible replacement I found is this one:
https://www.amazon.com/KeylessOption...nt+auto+remote
rltilley is offline   Reply With Quote
Old 03-05-2018, 05:02 AM   #2
Contact whoever installed your alarm system if only to learn what model you have. CompuStar is still active so I'm guessing or assuming they'll have replacement remotes available? https://www.compustar.com/systems/security
Those shown in your link are Ford factory RKE remotes, not usually compatible with anything from the aftermarket.
HTH
