Replacement or Alternative to ScanGuage
Has anyone tried one of these OBD2 apps for the iPhone. There are about 50 of them listed on the iTunes store if you search for OBD. DashCommand is the most expensive at $49. I think you also need a device to plug into the OBD2 port that converts the info either to wifi or bluetooth so it can talk to the iPhone.
My display is starting to give out on the ScanGuage and this would allow me to have one less device on my dash.
http://www.palmerperformance.com/produc ... /index.php
