Originally Posted by Ocsmb
Hi gang. Anything hazardous about this setup? Lol
Specifically, is it ok to run the fuse panel through the 300a fuse to the house battery or should I run a separate cable from the fuse panel to the house battery ?
So is this fuse for the Battery or the inverter/charger? Specifically it would be conceivable to have two one close to the inverter and one that is close to the battery. (Sportsmobile does not install a fuse just for the battery). Since both the battery and the charger are power sources you should have a fuse close to each.
Now moving to attaching the cable for your fuse panel. I would suspect that your wire size has dropped so that too would require a fuse or circuit breaker, again this should be close to where the power source. Looks like you are showing some form of circuit breaker there.
I would also move where you attache the solar controller power through it's own fuse block, a Blue Sea MAXI fuse works good here. This should be close to the controller as it is the power source. Depending on the length of cable between controller and the power connection, you may want to fuse the other end, as it would considered a change of wire size from a power source.
If using a good class T fuse holder like the Blue Sea Models you can safely attach 4 wires to the terminal
This is a quick drawing to give you the basic idea
Hope this helps, feel free to PM if needed.
