Old 08-04-2017, 02:31 PM   #1
Replacing Marinco cap for 30amp inlet
I think this was addressed a while back but I can't find the ref through the search engine. It's actually the hinged lid that's not working anymore and I can hear it flapping and bumping when on the road. I've gotten tired of taping it closed every time I use it.
So I've seen these Marinco replacements that usually seem to include the Bezel, which I take it includes the plugin and all. Before I started taking things apart and ordering stuff I thought I'd ask if I need to replace the whole thing or if there's some way I can just replace the hinged cover unit.
Also, when replacing it what precautions do I need to take to safely work on this? Is simply throwing breakers off going to be enough?
Thanks in advance!
-Scott
Makalu1 is offline   Reply With Quote
Old 08-04-2017, 02:53 PM   #2
rallypanam's Avatar
Yeah, you have to buy the whole unit.. but you don't need to replace the whole unit.
Marinco 301ELCB Marine Electrical Inlet Replacement Cap and Bezel https://www.amazon.com/dp/B000NI594G..._I6nHzbW8NRXFG
Actually, I may have the piece you need. Let me look this weekend.
Old 08-04-2017, 03:49 PM   #3
Nice, rally. I just checked to see if the inside part or bezel was part of the catch system but it looks like the cover and fixture go around the inside stuff. Mine's got 4 screws holding it on and looks like a black gasket in between. I'm seeing $25.68 at Lazydays RV.
Old 08-04-2017, 03:57 PM   #4
rallypanam's Avatar
Exactly. The actual plug and wiring fit into the cap/cover, but separate.. So you don't need to rewire anything, just remove and replace with new cap/cover.
Old 08-04-2017, 04:01 PM   #5
What I was hoping to hear.
Old 08-06-2017, 04:44 PM   #6
rallypanam's Avatar
I do have one.. Unfortunately it's also pretty loose and probably would rattle the same. Sorry!
Old 08-06-2017, 04:48 PM   #7
No worries, rally! I just ordered one online. Many thanks just for having your heart in the right place.
Rattle-n-hum
dar636
Ford
fabtechmfg
