Old 03-22-2017, 08:04 AM   #1
Replacing RV battery
Hi:
I'm in Boise and I've gone to a couple of RV service places about replacing the RV battery on my 02 Ford Sportsmobile.
The one in it now is a LifeLine GPL 4DL
210 AMP; 4D AGM.
Three places didn't want to handle it.
Any ideas?
Thanks,
Pete
mountaingoatz is offline   Reply With Quote
Old 03-22-2017, 08:27 AM   #2
B350's Avatar
Where is it located? Why not order the battery and install it yourself? It would be a simple extraction and installation.
http://sepbatteries.com/lifeline-gpl-4dl-agm-battery
'99 E350 EB 7.3L, 2WD, WeldTec lift, CCV Mid Top
B350 is offline   Reply With Quote
Old 03-22-2017, 12:47 PM   #3
If the RV shop won't do it have you asked a good auto shop to give it a try? The main thing to watch for are the physical dimensions of the battery and clearance of the lugs. As B350 posted, it's a fairly easy job especially for a shop. Make sure they know about the separator or isolator.
Old 03-22-2017, 01:16 PM   #4
Having just replaced mine, its not very technical, its more physical. Make sure you have a 2nd set of hands and a floor jack.
Botchan is offline   Reply With Quote
Old 03-30-2017, 09:09 PM   #5
Could anyone expand on what to tell the shop prior to replacement?
2003 EB350, 7.3L, SMB 4x4, "50" w/propane
Rustywolf is offline   Reply With Quote
Old 03-30-2017, 09:27 PM   #6
pugslyyy's Avatar
+1
SEP had the best prices when I replaced mine in 2013. If you can pump gas you can change a battery - it's that simple.
pugslyyy is offline   Reply With Quote
