01-29-2015, 08:06 AM
#21
Re: rocker switch placement?
Originally Posted by rallypanam
Yes, you can get TFT on Scangauge for 7.3s, at least the newer ones.
dang, how did i miss that?? its the first damn one time for some reprogramming. thanks for the heads up
01-29-2015, 08:39 AM
#22
Ok, pillar pods covered. Now what about rocker switches? I'd like to get some ideas too.
01-29-2015, 09:15 AM
#23
01-29-2015, 09:33 AM
#24
REF: Compliments! Your post is the most responsive since you show both rocker switches and over the mirror gauge pod. That panel of rocker switches is the cleanest I have ever seen. Thanks for linking those guys. What does the "Engine Start" rocker switch do?
01-29-2015, 11:40 AM
#25
This one would be handy .
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
01-29-2015, 12:58 PM
#26
Geeeeeez, now you got my attention !
Now I need gadgets for at least 23 different cool switches
'98 E-250 5.4 2WD Cargo Van
01-30-2015, 03:41 AM
#27
That video is awesome, good find. E350-thanks, it couldn't have worked out better, esp since I needed a row of 8 switches for all the various lights and engine start button, there really wasn't anywhere else to go. The engine start feature momentarily combines the starters with the house battery, in essence you can go jump yourself (might be my new saying now)....it is a feature of the sure power battery separators, I have not tested it, and I hope that it's wired correctly and doesn't send out the trunk monkey with a club!! That would be bad.....
02-15-2015, 04:52 PM
#28
Mine are just under and to the right of the steering wheel.
02-16-2015, 03:30 AM
#29
Looks good !
I ordered 8 switches for some gadgets, but still are undecided where to mount them. I also thought about this place, on the other hand a nice roof console would be cool too.
02-16-2015, 08:39 AM
#30
JoeyNick, can you tell me what brand that is and where you sourced it? I've looked at the marine places. They seem to have lots of this stuff at ok prices.
