I’m installing a new Front Runner roof rack this week along with a 55” LED light bar I bought on amazon (cheapie, $150 or so). I was wondering for those that have put any electrical on the roof how and where did you route the wiring into the cab? Hoping there’s a good clean solution someone has, preferably something that doesn’t involve putting holes in the van anywhere.
Not as clean, but a no holes required method is to run the wire under the rubber door seal. All my antenna wires are routed this way. You can pull the seal off the pinch weld, tuck the wires into it and then replace it. I've had no problems with closing the door on the seals with wires in them, just watch for chafe, and make sure to fuse correctly.
