Old 10-21-2009, 07:41 PM   #1
ScanGauge _Changing tire sizes?
Is it possible to calibrate the scangauge for different size tires.I'm assuming scangauge uses the tire size programed into the pcm. Am i correct, thinking about getting one.
Dave
unimogdave is offline   Reply With Quote
Old 10-21-2009, 08:06 PM   #2
yvrr's Avatar
Re: ScanGauge _Changing tire sizes?
There sure is....there is a specific function to accommodate larger tires to result in correct speeds, etc.. One way is to tell us what tires you use and someone should be able to tell you the percentage function to input into the Scangauge to correct for that size of tires. Otherwise, use a GPS to make an estimate and then fine-tune it.
Jack
'01 Ford EB50p Quigley 4WD
Old 10-22-2009, 09:46 AM   #3
Yes, you can make the correction on the scangauge. But, your dash speedometer will still be off. You will need a programmer to change that.
Reunel rear bumper
Old 10-22-2009, 06:52 PM   #4
Thanks for the info if that is the case then I will be getting one.
Dave
