11-05-2015, 04:06 PM
Re: ScanGaugeII trouble
You also might try plugging the whole deal into another car and see if it fires up. I plug mine into our BMW X3 sometimes and it works there with no issues. ScanGuage is pretty good about backing the product from my experience.
11-05-2015, 05:00 PM
Do you have another vehicle you could try it in? Then you'll know if you have to send it back or have an issue with the ODBII port. I'm suspecting power to the port.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
11-06-2015, 12:56 PM
Glad to know mine isn't the only one that "forgets to come on" every once in a while. Luckily it's extremely easy to remedy (poke button).
One other weird thing I have noticed: Once in a while (say every 30th night) I'll see the SG on the dash light up for about twenty seconds, then go off. This is with the keys out of the ignition, and the start and house bank disconnected from each other. Always wondered why, although it seems to cause no problem (other than each time I think there is a ghost in the cab before I remember it's the SG). I guess it's something happening in the Ford/start battery loop.
11-06-2015, 02:35 PM
I just noticed that this year on mine also. Didn't see it for the previous 5 years. Hmm...
11-06-2015, 02:39 PM
Same here! Though I changed vehicles (97 E-250 to 98 E-350 so couldn't rule out that as a reason.
11-08-2015, 07:51 PM
i tested the Scanguage on my wifes Subaru Crosstrek and it worked fine.
Ill have to check and see if its just a fuse on my van or if theres something else going on with the wiring.
Thanks for all the suggestions guys!
www.thevanpires.com
2001 E250 RB30 Agile 4x4
1976 G30 Pathfinder 4x4 SOLD
11-08-2015, 08:14 PM
OBD port power is shared with one of the power points on the dash.
11-09-2015, 04:58 AM
Yes---specifically Fuse #23, 20 amp located in the Central Junction Box or inside fuse box.
11-15-2015, 07:30 PM
thank you! it was just the fuse.
www.thevanpires.com
11-15-2015, 10:08 PM
#20
Thanks for following up - I was wondering how it turned out.
