Old 07-05-2018, 07:37 PM   #11
Glad to see that you got it working, I got to ask about your system. The wires size looks pretty small, by your post it seams that is measuring current going to and from the battery, from the whole system , lights , inverter, etc.
Old 07-05-2018, 09:22 PM   #12
It’s a great question and I don’t know the full answer yet. Note above that I was confused about what amps I should be seeing and what I’m not seeing.
The fridge and inverter are not on this circuit and have a much more appropriately sized wire. I think this is only “in-line” with the circuits that ground through the van frame and include anything connected to my rear fuse box.
This includes: solar, lights, and poptop lift (FYI - about 14amps max when starting to lift), water pump, and a stubbed out line intended for future rear shower if we ever decide manual isn’t good enough. So maybe not as bad as it looks? It kinda makes sense not to run the inverter through the shunt as it would pull too much amps anyway (shunt is 100a). But I think the fridge should be monitored.
In this photo you can see the smaller ground line that is on this shunt and then the larger line going to the inverter and fridge.
2017 Sprinter 4x4 144LR. Dialin' it in.
[RIP] 2004-2017 SMB PH, 4x4, E250v8. The wheels fell off.
Pritikin is offline   Reply With Quote
