SMB MAJOR wiring problem!
In the process of rewiring all the SMB switches( I did not like them on the driver kick panel ) I discovered a MAJOR problem. The extreme air is powered off the starter terminal(on diesels) mine was rubbing on the frame and close to shorting ( no fuse no breaker ) This could fry your whole van. I rerouted the wire and put friction tape all over it. The problem with wiring problems is they might not show up for years. Everyone really needs to check this. I now have a 16 terminal fused panel for all my loads.
Cheers
Jeff
P. S. Wait to you hear all my shock adventures....
2006 Sportsmobile PSD-----69 Jeepster----BMW1200GS---450 KTM----450YFZ--- 2007 F150----2005 Nissan
