Old 04-12-2019, 04:22 PM   #1
SMB Map Lights Only Work With Door Open
For some reason the SMB installed overhead map lights in the cab of my 2003 E350 only work if a door is open.
If a door is shut the lights turn off and the switch does nothing. If a door is open the lights turn on and respond to their switches.
I'd like to be able to use the map lights while the doors are shut. Is there something weird that might be causing this or is this expected behavior?
tnmarm is offline   Reply With Quote
Old 04-12-2019, 05:00 PM   #2
simplesez's Avatar
Is this something as simple as turning the knob? That is how it works in my van. The plunger knob rotates to control dash brightness and overhead light shutoff.
Old 04-12-2019, 06:23 PM   #3
REF
REF's Avatar
Send a message via MSN to REF
Yup, turn the headlight knob
Old 04-12-2019, 10:27 PM   #4
I have a 1998 E250 and it does the same thing. Evidently, the reading lights are wired into the existing Ford dome light circuit.
wltrmtty is offline   Reply With Quote
Old 04-15-2019, 12:13 AM   #5
Ron_Nunan's Avatar
Thanks guys.., this thread answered a couple questions..haha..not everything works as it should
Ron_Nunan is offline   Reply With Quote
Old 04-16-2019, 09:43 AM   #6
So the knob kind of solves the problem. When I turn the knob, I can control the map lights with the door shut.
But if i leave the knob turned, push the map light buttons to turn them off, then open a door, they dont turn on.
So, i cant get my ideal scenario of them turning on when entering, then being switch activated once inside the van. But this is a small enough work around to not be too painful or go wiring hunting to try and "fix" it.
Thanks again gang.
Guster
Salmon
The Yeti
TexGX
