Old 12-06-2018, 02:19 AM   #1
Should solar charge house or start battery side of the Blue Sea ACR?
Hello wise ones.
I have two 25x30 solar panels and a Specialty Concept Mark 22 SCC that came with the van. Pretty sure smb west installed them. Im unsure of how they wired it because when I replaced the house battery I didnt see wires from the SCC so I assumed the wires terminate at one of the start batteries. FYI I replaced the blue isolator with the blue sea ACR 7622.
So the Blue Sea ACR 7622 sits between my start batteries (qty 2 for my 7.3) and my house battery (Lifeline 4d agm).
1) What side of the ACR should I terminate the solar charging wires, house or start?
2) Do I have to terminate the neg wire from the solar charge controller (SCC) to the negative post of the battery or can I ground it to chassis?
3) I ask for your advice to see if its worth the effort to yank the existing wires and run them to the house battery instead.
Old 12-06-2018, 03:24 AM   #2
REF
REF's Avatar
Send a message via MSN to REF
Your solar charge controller wires are most likely located where the house fuse block is, theres a house battery terminal or distribution block, in my RB-50 that was under the sleeper sofa.
Old 12-06-2018, 07:50 AM   #3
The Solar Charger should go to the house side of the ACR. I would also run a ground bus that goes directly to the battery. It is worth it to yank, and replace.
2004 E350 EB V10 E/PH 2WD
Old 12-06-2018, 07:57 AM   #4
Also, the previous install had an isolator so it is conceivable that they wired the positive to the alternator post of the isolator. That way they could have charged both start & house batteries. If they wired to the start batteries, it would have only charged the start batteries.
Old 12-06-2018, 10:49 AM   #5
Thank you for the input. Why is it important to terminate the - to the negative battery post instead of grounding to chassis?
Old 12-06-2018, 10:53 AM   #6
Not sure where it would be.
And where the neg from the SCC would be either.
BCCD387C-49FC-43E0-BEEA-F4A858EF9F3E.jpg   57E88039-8B4F-4E8F-8CE3-30FE74806208.jpg
Old 12-06-2018, 12:56 PM   #7
In 2006, SMB ran the solar + to the house side of the my separator. IIRC the solar negative was ran to the ground terminal block close to the separator. There is a separate ground from the block to a high amp post where the 4/0 negative terminates coming from the battery bank.
Old 12-06-2018, 01:12 PM   #8
Thanks Dave. Ill take a closer look.
