Old 05-05-2017, 04:23 PM   #1
Solar first timer
I'm installing solar on my Ford Econoline 250 next week. I've got a 100 W 12 V renology starter kit. Any suggestions or tips for installation? Things you wish you would have done differently? Thanks y'all!
Rylee Ann
ryleecat is offline   Reply With Quote
Old 05-05-2017, 04:32 PM   #2
winmag4582001's Avatar
Use a water tight fitting to go through the roof.
https://www.amazon.com/uxcell-Waterp...rproof+Plastic
Really decide where you are going to put the battery and inverter. Its a pain to reroute wires later. Use a good inverter and battery. The cost can be high but the performance is higher. 1500 watt pure would be my minimum suggestion. You can also run a fuse block and run all your interior LED's, add a socket for a 12volt blanket, ect.
I've been running a solar unit on my son's race trailer for over a year and it has been 100% maintenance free. Love it.
In my van I run two house batteries via a VSR. It could be easily converted to solar charging.
2017 Subaru Legacy
1990 Volvo 240GL
2x 1987 BMW 535is
1995 BMW 540i6
winmag4582001 is offline   Reply With Quote
Old 05-05-2017, 04:49 PM   #3
Flux's Avatar
Renogy makes a cable pass through. Good bet on that.
Fuse everything, oversize your wiring, make good tight connections with well done crimps.
<br>
Old 05-06-2017, 05:46 PM   #4
BillPa1's Avatar
Do you know if anybody has mounted a solar panel on the driver side of their vans? I was thinking of a portable panel, but store it on the side of the van so it generates some juice, but more just as a place to store a portable panel. Thanks, BillPa1
BillPa1 is offline   Reply With Quote
