Old 05-05-2017, 04:23 PM   #1
Solar first timer
I'm installing solar on my Ford Econoline 250 next week. I've got a 100 W 12 V renology starter kit. Any suggestions or tips for installation? Things you wish you would have done differently? Thanks y'all!
Rylee Ann
ryleecat is offline   Reply With Quote
Old 05-05-2017, 04:32 PM   #2
winmag4582001's Avatar
Use a water tight fitting to go through the roof.
https://www.amazon.com/uxcell-Waterp...rproof+Plastic
Really decide where you are going to put the battery and inverter. Its a pain to reroute wires later. Use a good inverter and battery. The cost can be high but the performance is higher. 1500 watt pure would be my minimum suggestion. You can also run a fuse block and run all your interior LED's, add a socket for a 12volt blanket, ect.
I've been running a solar unit on my son's race trailer for over a year and it has been 100% maintenance free. Love it.
In my van I run two house batteries via a VSR. It could be easily converted to solar charging.
2010 Ford E350 EB 6" Weldtec Lift
2017 Subaru Legacy
1990 Volvo 240GL
2x 1987 BMW 535is
1995 BMW 540i6
winmag4582001 is offline   Reply With Quote
Old 05-05-2017, 04:49 PM   #3
Flux's Avatar
Renogy makes a cable pass through. Good bet on that.
Fuse everything, oversize your wiring, make good tight connections with well done crimps.
<br>
Old 05-06-2017, 05:46 PM   #4
BillPa1's Avatar
Do you know if anybody has mounted a solar panel on the driver side of their vans? I was thinking of a portable panel, but store it on the side of the van so it generates some juice, but more just as a place to store a portable panel. Thanks, BillPa1
BillPa1 is offline   Reply With Quote
Vantastic
maxx
Behemoth
Besags
