Old 02-12-2008, 04:25 PM   #1
Solar power - no charge
Looking for some troubleshooting advice on my solar system. My Blue Sky 2000E is showing no Solar Panel Current, and no Output Charge Current, even during the middle of the day. The Charge Mode is set to Normal. I've read the manual, but I clearly did not have an "ah-ha" moment.
I've had my solar panels flexing at highway speeds, with the crossbar bumpstops slamming my penthouse roof, so it could be damage to the panels or the wiring. I'm just looking for any experience or advice with the controller or panel wiring, so I can avoid a day off work and over $100 in fuel.
thanks in advance
BroncoHauler is online now   Reply With Quote
Old 02-12-2008, 07:29 PM   #2
I'm guessing the solar-panel bone is not connected to the controler-panel bone... have you checked all the wiring?
and then
everything changed
Old 02-13-2008, 02:12 AM   #3
Hello Herb,
I'll try to answer your solar controller/panel questions.
Remove the solar controller and check the voltage on the two pairs of wires connected to it. One pair is from the solar panels and one pair is from the battery, both pairs should be red and white 10 gauge wires. Confirm that there is no voltage across the wires connected to the 'array' terminals. If there is power across these terminals (usually about 17-18 volts DC when the panels are exposed to full sun without any shadowing), then you know the panels are producing power and perhaps the problem is with the controller. If there is no power at these array terminals, you should see if there is any output at the panel itself. You should get a reading of about 17-18 volts DC across the two wires that come out of the small black control box on the solar panel when the panel is exposed to full sun without any shadowing. If you don't, check the connections inside of this small black control box. If you still don't have any output from the panel, it is probably bad.
Loose or corroded connections can be the problem too, so check that all connections are good. There could be some connections under the velour trim on the penthouse rail that need to be checked also. A simple
"pull-test" on the wire at each connector will confirm if the crimp is "good". A bad connection is the most llikely scenario.
Good luck!
John K.
John Kalmbach is offline   Reply With Quote
Old 02-13-2008, 07:26 AM   #4
Thanks John, I'll do that.
The controler owner's manual does mention an inline fuse, but if there is one, I don't know where it's located. I do have a 30A fuse in a spot labled for a Furnace, but I don't have a furnace. It might just be a spare. That fuse, along with all otheres in the fuse panels are good.
Old 02-13-2008, 09:14 PM   #5
Herb I had SMB install the same controller and wondered why I have never seen as much current as I did with the old controller. I do see some flow, but it's been from less than 1/2 amp to only about 3 amps. Before I had over 6 amps typically. Sounds like yours is flat out dead. I am assuming that if the batteries are fully charged the controller will keep the amps low. I will have the chance to test it this weekend. I read this and I hope it's correct or I too have a problem.
"The lower the state of charge in your battery, the more current a MPPT puts into them - another time when the extra power is needed the most. You can have both of these conditions at the same time".
Dave Boyer
Old 02-13-2008, 10:13 PM   #6
Before my problem, my controller was showing up to 5A, so something has changed.
Old 02-14-2008, 04:42 PM   #7
VANZILLA's Avatar
Herb -
Might want to double check this isn't the problem. I believe John's voltage test of the panels would tell. I copied this from Badger's website.
"After some time we noticed that the solar input seemed lower than expected for the time of year, but would fluctuate, sometimes matching expectation. Finally tracked it down to the "flexible" Solara solar panels. One of them had a number of cracks in the tinned copper traces running between the constituent cells. It appears that when it had been trod upon, the sharp edges of the silicon wafers had cut the traces that transitioned over the edges of the cells. Just flexing the panel a bit would drastically change its current output. I carefully examined each trace at the transition points, cut out the rubber coating over each one that appeared cracked, soldered the cracks, and re-sealed the cuts. Panel output became high and consistent."
Cheers,
Don
2006EB 4x4SMBw 6l PSD PH Custom - "Zilla"
VANZILLA is offline   Reply With Quote
Old 02-17-2008, 04:57 PM   #8
Originally Posted by John Kalmbach
Hello Herb,
Good luck!
John K.
John,
At the back of the Control Panel, I'm showing zero volts across the two PV panel inputs.
Going to the panels themselves, at each CellProtector, I'm showing 12.2V, at approximately 2:00pm, with minimal shadowing. Though this is clearly low, shouldn't it be enough to provide at least some power to the Control Panel? Maybe I have a combination of problems.
Old 02-17-2008, 11:17 PM   #9
solar
Hello Herb,
If you're seeing some voltage at the solar panels, but none at the controller, then there is probably a loose connection (bad crimp) between the panels and the controller. You coud also have some corrosion at the panel itself. The small black cover will unsnap and expose the contacts for inspection.
The solar panel output is really effected by even the slightest of shadowing. For instance, a Yakima or Thule crossbar will reduce the panel output by at least 15% if the panel is mounted fore/aft. If it's mounted across the van and has a crossbar shadowing it, don't expect anything out of it.
I'm not sure what the minimum voltage input is for the controller to operate, but you're not even getting the 12.2 volts from the panel to the controller. Usually the solar wiring is routed up the front driver inside corner of the PH canvas. There may be some connections under the PH rail velour trim that need to be re-crimped. You can also check the voltage at the 10 guage red and white wires routed in the front driver corner, if there is not the same voltage at these wires as at the panel, then the problem is between there and the panel. If you do have the same voltage, then the problem will be between the point of the voltage check and the controller.
I hope this helps.
Thanks,
John K.
Old 03-20-2008, 10:56 PM   #10
Just got back from a business trip, and from driving the SMB back home from SMBw.
Turns out the solar panels themselves were bad. Don't know if it was a quality issue, or the constant flexing up and down of the panels.
The NEW panels are mounted in an angle iron (aluminum) four sided frame. There is much less panel flex than before, and no more thumping of the panels on the penthouse roof.
