One advantage of breakers over fuses is to Midnight Solar. If you google the breakers in that diagram it shows the breakers are sold by Midnight Solar. Could they be re branded? Just to be forthcoming I have a well developed opinion about Midnight Solar. And I'm not an electrical engineer.
One thing that I believe is good practice (with low voltage DC) is to touch your stuff.
With each piece of equipment running (inverter, solar, charger, hot water heater, ect) at it's
full capacity follow the wire, connectors, fuses, with your hand and see what is getting warm. You might have to run it for half an hour or more. Every component that is warm is lost power. In the case of a solar system that's watts of precious expensive power not getting to your batteries. All that warm air blowing out of your inverter, that's the 10-15% of loss that's in the literature. It seems like old Dad advice but it's a cheap way to find where to improve the efficiency of your system.
Just a note, when I still had the original SMB fuse block (12volt) it had an automotive type breaker for the main incoming power. 50 amp I think. That thing was always hot with just a few amps running. I put a volt meter on it and I was losing something like .75 volt of loss across it which seemed unreasonable. I've since made drastic changes.
[edit] Flux- in case you were wondering, in an ideal most safe solar design you would want a fusable device everywhere there is a breaker in that schematic. It wouldn't nessacarily need to ba a circuit braker though and that layout is the norm for permanant/house type solar. I don't have quite that many fuses in my system. Like between the panels and the junction box or a GFI.
-Eric
