I'm currently being held captive waiting for a delivery that I must sign for. So lets talk about fully charged lead acid batteries. Bear with me as this may be obvious for most members.
Fully charged (very loose definition) is that point where a
high enough voltage has been applied for
long enough time where all chemical reaction within the battery has stopped. To continue to apply a higher voltage or for more time from that moment the electrical energy will only be converted into heat. The proverbial "boiling a battery". This point in the chemical reaction is accurately determined with a hydrometer but how do you determine in a sealed battery or a battery that is inaccessible. You make an educated guess.
Here is my method.
1) Find out what the manufacture of the battery states the Absorb or Cycle Use voltage should be. Not what any charger/controller manufacture says.
Here is the data sheet for a UPGI battery, since a lot of us have these.
http://files.upgi.com:8086/UPGFileSe...pecSheet/45972
You will find Cycle Use is recomended to be between 14.6 and 14.8 volts at 77 degrees F. Call it 14.7
Here is for LifeLine as a lot of us have these.
http://lifelinebatteries.com/wp-cont...cal-Manual.pdf
Absorb voltage is 14.3 volts at 77 degrees F. found on page 19.
2)Apply the charge to the battery bank until that absorb voltage is reached. I like to use a plugged in manual charger or power supply as it won't turn off or lower the voltage on me. If that is not available use what you got that will go high enough for long enough. If all you have is a Progressive Dynamics with a charge wizard it will only get to 14.4 volts in manual mode then that what you use.
3)Once the voltage reaches the absorbe voltage(14.7, 14.4, 14.3) I start a stopwatch. when this stops, this time will be the absorb time at 77 degrees F.
4) Determine the stop time for Absorb. Here is where the money is. Using the assumption that when the flow of Amps drops to 2% of the Amp Capacity of the battery or bank charge is complete. So in boywonders case he has 250 amp Hours of capacity, 2% of that is 5 amps of charge current. So holding his battery bank at his charge voltage for enough time to see the Amps flow drop to 5 I would stop the watch and call it fully charged. This is the time to zero out your monitor so it reads 100%.
This regime is ideally what you want your solar charger to repeat on it's own or as close to it as possible. If I can get these results during a battery assessment I would then assume the battery bank is healthy and move on to other equipment like solar controller and monitors.
- Eric
CORRECTION : boywonder has 350 amp hours of capacity. So his 100% fully charged point would be 7 amps at the Cycle Use voltage. 350Ah x .02 = 7Amps.
