Sure, this should be a good starting point
Van Battery Connects.pdf. In reality I don't really disconnect the battery, but instead I disconnect the power distribution. I also have a separate manual disconnect for always on power.
In any case I use the BlueSea 7713 for this disconnect. I have the switch wired in to provide manual control, but basically if the 7713 has 12 volts on the control input it stays connected. remove 12 volts and it disconnects. Between that switch I have a relay that is controlled by my Pentametric Battery monitor, this relay is triggered by a low voltage setting in the battery monitor. Obviously this is optional. The power for the Blue sea control switches come from the always on circuit, this allows them to turn the switch back on. The downside is that even if I throw a low voltage disconnect via the Pentametric I have power draw from the always on devices.
I do have a separate disconnect for my solar input, but the inverter/charger does not have a separate disconnect.I use a Bluesea 7701 for that, mainly because it is what I had, it is much more difficult to use a "controlled" disconnect, but is fine as a disconnect switch. I use Bluesea ML series Link Bus "9160" to connect the three switches together. I also use Bluesea MRBF terminal fuses for various power distribution. There is one going to the van battery I have a similar fuse on the van battery since the power cable is bidirectional. The next fuse is for the Power Distribution fuse panel, and then the third is for the Always on Power distribution. The house battery has a class T fuse close to the battery and also a class T fuse is on the output/input of the inverter/charger per their recommendations.
The 7622 ACR also has a relay between the switch and the unit, this is totally optional, and comes down to a personal preference. This relay puts the 7622 into auto-mode when the van is running, when the van is not running it goes by what ever position the switch is in. By default I normally have the switch off, disabling the ACR, If I want to top off my batteries with solar or the house charger I will set the switch to auto. With this setup, I do not find the need for the ignition lockout wires of the ACR, I suspect that I would wire them in if I was not using this extra circuit.
In theory, I set it up this way to provide the low voltage disconnect, but also provide the ability to power the distribution fuse panel via the van alternator via the 7622 ACR. I can manually disconnect the fuse panel via the switch while still providing power to the items that I use while driving. This allows me use solar for a better charge profile then the alternator provides, also a better float voltage while long drives. This was impart done with a future thought of lithium batteries.
Other thoughts, the solar has a fuse at solar controller, but since there is some heft to that wire , in the future I may add a another MRBF fuse to the solar side of the disconnect switch. Although power should not feed this direction, there is a subsequent amount of current valuable on that side, it is fused at the battery and inverter, but in the case of a short it may be a issue.
Also, I may look at also having some control over the always on power with the Low Voltage disconnect provided by my battery monitor.
I hope this helps, and feel free to ask any follow up questions, I probably should have had more coffee before answering this.
