Old 10-11-2011, 09:58 AM   #21
SheepShagger's Avatar
Re: Switch panel
Originally Posted by ANZAC
Originally Posted by SheepShagger
Then just made the front labels with a laser printer.
Did you tape them on or glue them on? Is that just black printing on white paper?
You can get transparent paper that's sticky on one side, I just printed on that paper (laser not inkjet), then cut them out and stuck them to the switches. I found a PDF online that had all the labels and symbols and used that.
Carling do actually make pre-labeled switch covers but since a distributor needs to order 100+ of each label, very few people stock them much less have a full set to pick from.
Old 10-11-2011, 02:25 PM   #22
ANZAC's Avatar
Re: Switch panel
Cool. Link to symbol PDF?
Sportsmobile-less.
Old 10-11-2011, 02:49 PM   #23
Re: Switch panel
Here is a set you can buy pre-printed.
http://www.mudstuff.co.uk/Carling_Legends.shtml
check your PM for a similar PDF you can print your self.
