Re: Time for an inverter - how to size?
I use a Harborfreight one as well; works great. I wired it directly to the VAN battery with some fairly large wire, fused. I use it almost exclusively to charge laptop batteries since these usually require more than 12v. I use the van battery because generally I want to charge them while driving and not run down my house batteries. But I've got connectors so I can do that if needs be.
I would suggest that you look for a 12v charger (cig lighter) for the two camera batteries, IF they are external. Whether you could make one for an internal battery depends on whether the appropriate charging circuitry is in the camera, or in the charger itself.
