Re: tripp lite just flashing
Are you saying the green light on the top right is blinking?
From the manual
“LINE Green LED”: If the operating mode switch is
set to “AUTO/REMOTE”, this light will ILLUMINATE
CONTINUOUSLY when your connected
equipment is receiving continuous AC power supplied
from a utility/generator source.
If the operating mode switch is set to “CHARGE
ONLY”, this light will BLINK to alert you that the unit’s inverter is
OFF and will NOT supply AC power in the absence of a utility/generator
source or in over/under voltage situations.
So if you are set to charge only then you would see that. The other traffic light on the left gives you battery capacity which all off would be 1-20%. I can't say I have ever seen these completely off and charging. What is the shape of your battery? Overtime did the left hand lights change?
I have attached a manua l. I hope this helps.
