Old 06-13-2012, 04:44 PM   #1
Tripp lite RV1250ULHW inverter
I just bought this inverter and love it. It's doing everything I need it to, but I don't have the remote display (yet) so I have a question for any Tripp Lite folks. It has 3 LEDs to monitor battery status but the manual has these listed in %, not in voltage. In other words, top LED lit is 91-100%, top and middle 81-90, middle 71-80, etc. anyone know the voltage readings to match the % values? I ask this mostly because I've been told to never drop below 11 volts, so are they saying 11v is 0%? Or is 0v=0%???
Old 06-13-2012, 10:17 PM   #2
Re: Tripp lite RV1250ULHW inverter
This is from the 12 Volt side of life. http://www.marxrv.com/12volt/12volt.htm
You should try not to go below 50%
Also if you want to make your own remote for the trippLite try this link
http://www.flickr.com/photos/3dking/6122643586/
If you just want a remote switch, you just need a switch between pin 1 & 7 on the cat5 cable. Shorted is Charge Only open Auto/Invert
Greg
Old 06-16-2012, 09:09 AM   #3
Thanks scalf, I'm already on a trip so I can't fool with it much til I get home now, but thanks for the info. I had forgotten about the 12v side of life. Good info.
Guster
Salmon
PigPen
velo47
