Re: Warning about glass panels
I called the manufacture and they said the panels are vacuumed sealed so there is no way to replace the glass. I just ordered another. I’m going to keep the bad panel because they said it should still work, just won’t put out as much. I also found a short load antenna so at least that problem will be solved.
