Old 03-07-2016, 10:58 AM   #1
stiggs's Avatar
Send a message via ICQ to stiggs Send a message via AIM to stiggs
Water Pump Kaput!
So after my last outing seems the water pump was left on, and now it hums but no water is coming out. Thinking its not priming or it has died.
So if the later has anyone changed one out? Trying to find what would be the right replacement on the ol interwebbies.
2000 Ford RB30 PH 2WD -- Eagle Rock California
stiggs is offline   Reply With Quote
Old 03-07-2016, 11:38 AM   #2
Might want to make sure your system is OK first. A thread from a while back that stopped w/o an answer but is similar to your issue:
http://www.sportsmobileforum.com/for...n-14917-2.html
Geoff's write up on replacement:
http://www.sportsmobileforum.com/for...pump-1194.html
Old 03-07-2016, 01:36 PM   #3
Fill the tank with water, remove the discharge hose from the pump and turn it on briefly. If the motor runs, but no water comes out it's probably the pump head. What type is it?
Old 03-07-2016, 02:13 PM   #4
stiggs's Avatar
its a shurflo 2088-403-14
Its making noise, but not pumping
this looks like a viable replacement
Robot Check
Old 03-07-2016, 03:55 PM   #5
Unless the suction side is airbound, the check valves have probably gotten hard and are no longer sealing. When it was left on, did it run dry? That can get them hotter than normal, again compromising the rubber check valves, although I once left mine on and weeks later my neighbor called me to tell me it was on. He went inside and shut if off, and months later it still worked.
Old 03-07-2016, 04:00 PM   #6
stiggs's Avatar
no it was only on over night and the tank was half full of water
Old 03-08-2016, 04:41 PM   #7
If the tank was half full, the pump wasn't pumping. It may have been on, but unless the fill valve was open the pump should not have been running.
I've left mine on for days and no probelms.
Old 03-09-2016, 11:27 AM   #8
stiggs's Avatar
So is this pump repairable? Right now all it does is hum and not produce water.
Old 03-28-2016, 11:48 AM   #9
stiggs's Avatar
I replaced switch assembly with this
http://www.amazon.com/SHURFLO-94-231...ilpage_o00_s00
Works great again.
Old 03-28-2016, 01:58 PM   #10
