06-12-2014, 12:05 PM
Re: weird LED auxiliary taillight activity
Originally Posted by carringb
Might be the multi-function switch. Could be dirt limiting current, and your incandescents are pulling all the current.
FWIW most trailers I pull are LED and I have not had that problem, except I noticed the hazards on the rear of the van don't really flash when I have the trailer plugged in (weird, huh?). But... it'll barely flash incandescents on a trailer (4-ways..... works fine with turns and brakes). I think the hazard circuit maybe just has less current capacity than the other functions.
I suspect if you unplugged your regular taillights, the new bumper lights would flash normally.
Don't think it's dirt, it's all new wiring with high quality crimp connectors that I also solder.
I suspect you're right about some current issue with the same circuit trying to run incandescent and LED with a flasher relay thrown in. I may give up and try incandescent aux lights, I can get a set for about $15. It may well be easier than trying to rewire everything, or switching stock lights to LED, but then having to swap relays or something else.
Argh.
06-12-2014, 12:44 PM
Shouldn't matter, I run LED trailer lights and they work fine. Your issue is specifically with the hazard mode and I recall there is something weird about how that works on the E350 trailer wiring.
Sportsmobile-less.
06-12-2014, 03:04 PM
Ground the bumper/trailer lights through the trailer harness and not through the bumper
06-12-2014, 03:23 PM
Yup, that's the way I wired it.
06-12-2014, 05:00 PM
I meant dirt in the multi-function switch. I've noticed gunk kinda like to buildup at the base of the hazard button in particular.
06-12-2014, 07:03 PM
My brain hurts. Works perfect with incandescent 1157 fixtures. But I spent good money on these damn LEDs and they look prettier! Must make work!
06-12-2014, 07:20 PM
Also tried ANZAC's method of tapping straight to the stock light housing.. no change in symptoms.
06-12-2014, 07:53 PM
Move on to Leavitt!
06-12-2014, 09:33 PM
Originally Posted by daveb
Move on to Leavitt!
Perfect. Camping, campfire, beers, and 6 guys looking over rallypanam's shoulder offering all sorts of advice while he tries to fix it.
06-12-2014, 10:42 PM
#20
Move on to Leavitt!
"I wouldn't do it like that!"
....is one of my favorite lines.
