Old 05-02-2011, 08:34 PM   #1
What type of electric componets and brands do you recommend?
HI. I have a 2005 E250 gas van. I am planning on doing a home built conversion. I would like some advice on what to buy. I want to keep the conversion reliable, simple and on a budget. I am trying to decide what electrical components I would need. I will have a friend install the components. I would like to keep the cost of the needed hardware below 2 thousand if possible (2 thousand does not include the price of the fridge, tv etc.).
I want to be able to run a microwave, tv with dvd player, refrigerator (not sure if I want a 12volt or the 110 type), maybe a lap top computer , charge the cell phone/ IPOD, fantastic fan.
Not sure if I will get an air conditioner or heater.
I would like to add maybe 4 or 5 12 volt outlets and 4 or 5 110 outlets.
I am not sure if I should get one or two batteries. Maybe buy 1 now and add 1 later?
What batteries do you recommend? Brand? Model number?
What type of separator should I get? Brand? Model number?
What type of inverter should I get? Brand? Model number?
What type of battery charger? Brand? Model number?
Will add an outlet for shore power. Model number?
The seperator charges the battery while driving?
What associated hardware, cables, fuses etc. do i need?
Any advice and recommendations would be appreciated.
Thanks in advance.
devildog is offline   Reply With Quote
Old 05-02-2011, 09:41 PM   #2
Re: What type of electric componets and brands do you recomm
You're gonna get a lot of replies that vary. Much of what you ask can be found using the search feature on this site.
All that is possibly with the correct inverter.
I have a diesel heater and like it. There are many posts on the Espar Airtronic and Suburban propane heaters. Both work well. Portable propane can work as well but electric heaters pull too much unless you're on shore power. Air conditionars are nice but eat up hugh amounts of power and are suited more for shore power. Danhard is SMB's choice unless it's a roof top style. An on board generator is another way to run one. But I have the old Starcool and it works great on the road. On AC power it might knock off 15 degrees of the outside temp. 100 out, maybe 85 inside...not much for the cost. On the road it will freeze me out.
Sure why not.
I suggest a good 4-D AGM such as Lifeline or Deka. I'd stay away from wet cell batteries but thats just me.
I got rid of my surepower 1315 and went with Blue Sea 7622...I like it.
I have a 2000w Xantrex prosine. It's also the main charger.
My inverter does the charging but don't forget solar.
Most RV shops have them. Mine is 120v 30 amp model
It disconnects when needed and charges whenever it see a charge voltage.
I'd run 1/0 copper between the batteries and 4/0 or 250mcm to the inverter. Might be a good idea to fuse it with some 300 a fuses but most are not. Install a GFI for stuff by the sink area.
Those are just a basic answers. This link might help and has other better links within it. I'm sure others will chime in with good info as well
Good luck.
Old 05-03-2011, 02:43 PM   #3
charlie56's Avatar
FWIW
You might consider what a few of us have done, and that is to eliminate the 110v system. The only item you listed that needs 110v is the microwave and that can be powered by a low cost dedicated inverter.
Take a look at a couple of threads that talk about the concept.
viewtopic.php?p=31455#p31455
viewtopic.php?p=2974#p2974
... Charlie
KZ6T
