Old 12-15-2011, 07:49 AM   #1
What's the Difference?
I'm ordering my new SM but I need to know if the "battery monitor" option is worth the cost compared to the std meter? What's the Difference? (I'm not going to get solar)
2012 Ford Sportsmobile Penthouse
h2o6457 is offline   Reply With Quote
Old 12-15-2011, 09:29 AM   #2
Re: What's the Difference?
I think the monitor (Magnum ME-BMK Battery Monitor Kit ... I think this is it) would be worth it. I see SMB charges $318. The unit on-line (if it's the same one) is about $150, but installation could be tricky and, to me, would be worth the extra $150 or so that SMB wants ... I would love to have one, but would need someone to install it.
One questions would be how it works if you have 2 house batteries?
Salivan
salivan is offline   Reply With Quote
Old 12-15-2011, 09:45 AM   #3
I wasn't aware there is a standard meter. If you're talking about the little handheld meter that just plugs into the 12 socket, there is a big difference between those and something like the Xantrex battery monitor (XBM). If you install a high end inverter, many of them come with a control panel that has a very accurate meter. Even though I have that type of inverter, I still have a Xantrex Link-10 battery monitor and suggest the XBM (or similar) are worth looking into.
>Shows current as well as voltage. Having the ability to monitor current is a great tool.
>Helps to make sure the voltage doesn't drop too low (some have alarms)
>Some have temp probes to mount on the battery that monitor charging in hot weather.
>They act as a fuel gauge for the batteries. Gives you an idea how much energy is left.
>They can help in trouble shooting a problem.
Will the standard plug in work...sure. Don't let the AGM batteries drop below a resting voltage of 12.2 and charge them up the next day whenever possible.
A better volt meter could be added at a later date for a bit higher price.
Old 12-15-2011, 09:51 AM   #4
Salivan
To monitor both chassis and house batteries would require a switch or a dual battery monitor…many boats have them.
Twin or multiple battery systems are bussed together as a rule so the monitor see them a single large battery.
This is worth a read:
About RV battery monitors
