Re: 110V hot water heater - looking for feedback.
if the valve is a so-called "1/4 turn" valv, like a ball valve then it is almost always set up so that if the lever is across the pipe, it is closed. only way i've ever seen it NOT that way is if someone took the lever off and rotated it 90 degrees for clearance purposes in some weird installation.
i dont knoww hat to tell you about winterizing.
Joe Skrivan
E-350 V-10; Penthouse, Custom Interior
