Old 06-14-2014, 11:47 AM   #11
Re: 12v air conditioner vs Danhard
Ive seen 6 different pro air units, they all had their own compressors
k9sprinter is offline   Reply With Quote
Old 06-14-2014, 12:03 PM   #12
ANZAC's Avatar
Oh sorry, I meant it has a engine belt driven compressor, not a stand alone electric one.
Sportsmobile-less.
Old 06-14-2014, 12:30 PM   #13
5 had engine driven , only 1had an electric
Old 06-15-2014, 07:01 PM   #14
I have the newer Danhard unit in my 2008 SMB. It is 110 but I can run it on the highway without issue from the house batteries and inverter. Just did it today in fact. Cannot use it in stop and go because the alternator just barely keeps up with power draw at highway speeds. Actually it uses slightly more, but if you start with 80%+ charge it holds fine.
Hope that helps. It also works great on shore power here in the humid south. Camping would be impossible, IMO, in July-Aug without it.
scottman is offline   Reply With Quote
Old 06-20-2014, 02:54 PM   #15
I ended up going with the Danhard.
Thanks for all the helpful replies.
Frank
Thanks,
Sffranky
SFfranky is offline   Reply With Quote
Old 07-24-2014, 11:07 AM   #16
tonyvoudy's Avatar
I got the Danhard with my van and have enjoyed using it on hot days when I am able to plug in. Hopefully this was an isolated incident but last year I was camped down in Florida in the sun at a state park with the AC on. Towards the middle of the day, I noticed water near the AC air intake vent. It looked like someone poured a bunch of water and it was draining from under the wood. I could not see any problems by removing the vent alone and just put some towels over the area until I made it home to do a deeper dive.
Once I removed the entire wood panel (and all the seals for the wood) I saw the problem:
Turns out the chiller unit "shifted" and the rubber hose that connected to the drain hose was crimped, effectively not allowing the unit to drain.
I never really understood why the hose was added to begin with, but after removing it, and re-positioning the chiller, I ended up with something more manageable:
I did sustain water damage to the wood panel and hopefully with no more repeat occurrences, I won't see anymore damage.
Hopefully this is an isolated issue and no one else has seen this problem for their Danhard units.
-Tony V
tonyvoudy is offline   Reply With Quote
Old 07-27-2014, 08:28 PM   #17
FWIW I am quite happy so far with my cheap AC solution for being parked with the penthouse top up.
viewtopic.php?f=16&t=14101
I punched some grommets into a weather fly and gave it the thunderstorm test: no problems. Works great, sets up in a minute or two once the pop top is up, can cool the van interior to below 70 with 95 degree Virginia humidity outside, is the cheapest solution I've seen, and replacement parts etc are a Walmart away.
Might not be a good solution for everyone though.
mpfreivald is offline   Reply With Quote
Old 02-10-2015, 02:00 PM   #18
Frank
I know it has been a while... but how has the Danhard treated you so far?
mlts22 is offline   Reply With Quote
Old 08-05-2017, 02:40 PM   #19
Originally Posted by k9sprinter View Post
there is a another option ... take your business to another conversion company
I thought the reason in getting a SPORTSMOBILE .. was to have it built YOUR WAY, with the equipment YOU want and need.... (and....... they know EXACTLY which Sportsmobile did my built)
K9sprinter,
Can you guide me in the right direction to who has this AC non shore option. Thank you so much.
Surfside17 is offline   Reply With Quote
