Old 04-29-2013, 02:48 PM   #1
ProfessorPaddle's Avatar
AUX Gas Tank
What is the name of that Gas tank that mounts under the rear tire where the spare would normally be? I thought it was called Transfer Flow but I can't find the thing listed on their website.
Thanks
2006 E350 6.0L (VanDelizer)
1986 Vanagon Syncro 3.3L SVX (battleCat)
1984 Vanagon GL (Chuckie)
1980 Vanagon Westy (Taylor)
ProfessorPaddle is offline   Reply With Quote
Old 04-29-2013, 03:04 PM   #2
Re: AUX Gas Tank
Is this what you're looking for? Plastic tank made for a cut-away chassis.
https://titanfueltanks.com/shop/utility ... s-8020199/
Old 04-29-2013, 03:21 PM   #3
Pschitt's Avatar
Re: AUX Gas Tank
Chris at U-Joint Offroad is also doing a prototype for me. You should ask him...
Old 04-29-2013, 03:51 PM   #4
Re: AUX Gas Tank
That sounds good I like Chris's Products.
Just fitted his bumper onto my van, getting the winch system and lights put on tomorrow.
I thought Transfer flow actually made a tank for the E series, the Titan tank listed above might work if you Fabricated a system to hold it in place and then also to run the fuel all the way to the main tank or to the fuel lines, but still it is not an exact kit or fit. You would be doing some serious tinkerin.
I just want to buy something ready to go and slap it in place, I don't mind getting dirty but I don't have the time to Fabricate some shopisticated solution.
Old 04-29-2013, 04:06 PM   #5
Re: AUX Gas Tank
TransferFlow makes a rear 27 gal tank, but you have to have it installed at a Mobility Upfitter.
Titan and Ford both have rear 40 and 55 gallon tanks that will fit if the spare is removed (55 on EB only).
Old 05-06-2013, 04:51 PM   #6
UJOINT's Avatar
Re: AUX Gas Tank
Bumper looks great on there!
We are working on a aux system that goes with our rear skid/underfloor storage setup. I'll have more info soon, keep posted to my site.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Ford
fabtechmfg
[HOONIVAN]
Shaggy
